Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Slicing Issue
3 REPLIES 3
matthew.kennedy4JQJ9K
423 Views, 3 Replies
Slicing Issue
I'm having an issue slicing part of a helmet. The part I'm trying to print is shown in yellow and it shows the fins on the sides at the top. When I slice (red image) these fins're greyed out indicating they won't print. If I scale it so the whole part's smaller they will print. I'm at a loss why this should happen.
Labels (1)
3 REPLIES 3
Most probably, you need to build support structures for the 90° overhang regions?
Slicer?
Gunter Weber
Triangle Artisan
Thanks for your reply. I'm using Cura 4.7.1. Have to admit manual supports didn't come to mind I'll give that a try tonight.
Still confused why it would generate supports when the model's smaller even with the same settings?
Turned out there were errors in the STL file. I fixed them using Netfabb now it'll print the supports.
Thanks again for your help.
