Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Slicing a model in half to get a bas relief
2 REPLIES 2
beroger0
437 Views, 2 Replies
I have a 3d model in an STL file format.  I want to basically create a sliced view of the model on a flat back ground to get a bas relief type model.  Can this be done in meshmixer?
2 REPLIES 2
MagWeb
in reply to: beroger0
Several ways... depending on what you've in mind...
To cut an object: EDIT/PlaneCut
To add a base cuboid:  MESHMIX>Primitives>Cube (Scale/Move it to the desired position).
To weld an object to a base cuboid: Activate source object plus base object and do EDIT/BooleanUnion.
or .... or..... or...
More info about your task?
Gunter Weber
Triangle Artisan
beroger0
in reply to: MagWeb
Thanks,  Edit | PlaneCut  did the trick
