Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Sculpt tool - draw inside
2 REPLIES 2
junkmail7412K62X
453 Views, 2 Replies
Is there any option to use the draw tool in such a way that it will push inside the surface, instead of pulling it outside? Instead of making a "mountain", I want to make a "valley".
Using the drag tool is not so comfortable because I can't paint with it like I do with the draw tool.
2 REPLIES 2
MagWeb
in reply to: junkmail7412K62X
Holding down Ctrl (Cmd on macOS) inverts the action of a brush:
For the Draw brushes: Instead of pulling triangles outwards > you will push them inwards (That's what you ask for)
For the Flatten brush: Instead of sucking the faces to an average plane > you will get higher peaks and deeper valleys
For the Inflate brush: Instead of a spheric growing > you'll get a spheric shrinking
For the Pinch brush:  Instead of pulling vertices towards the center of the brush > you will push them away from its center.
For the Attract brush: Instead of sucking faces to a target > you will push them away from the target
For the Spikes brush: Instead of building a spike > you'll dig a cavity
There are brushes where an inversion doesn't make sense (Drag, Zipper, Smooth....)> so there's no such functionality.
Note on the Pinch brush: As said this brush pulls the surface towards its center. This center depends on the Depth slider. So if you set the depth to a positive value you pull the vertices to a bigger distance > inwards. A negative Depth value sucks them out  to a smaller distance > outwards. That's a most powerful option.
Gunter Weber
Triangle Artisan
sypernova6969
in reply to: MagWeb
Man this is a god send.  I tried using Meshmixer 3 times int he last 2 years, and because I didn't know about ctrl, I ended up uninstalling.  thanks!
seb
