Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Scanned Plastic Part
4 REPLIES 4
deonh99
377 Views, 4 Replies
I am in the process of restoring an old motorcycle and some of the parts are no longer available. I managed to get hold of a very high-resolution 3D scanned model in .stl format of one of the plastic covers. Once imported it looks great, but upon closer inspection, the outer recessed border is very wavy instead of straight and defined. Is there an easy way to straighten/sharpen the edge?
4 REPLIES 4
deonh99
in reply to: deonh99
I like the "upper" surface suggestion as it is a plastic part.
Would you suggest "reverse engineering" as an option as the angles and curves are quite complex although it does not look like it and do you perhaps have any resources that can help in that?
hfcandrew
Yep reverse engineering. Someone good with Fusion360 could do this in an hour.
Make a post on their forum:
https://forums.autodesk.com/t5/fusion-360-design-validate/bd-p/124
And fyi actually someone just posted the exact same kinda thing: https://forums.autodesk.com/t5/fusion-360-design-validate/reverse-engineering-stl-file/td-p/12324872
deonh99
in reply to: hfcandrew
Thank you so much and yes, that will help me too 👍
