Meshmixer
Welcome to Autodeskโ€™s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Scaling a planter & scaling thickness differently
2 REPLIES 2
393 Views, 2 Replies
Sorry for the noob question, I'm still trying to wrap my head around what tools exist & how to use them.
I want to scale up this planter model by 2.5x but I only want the thickness of the walls to be 1.5x as thick. Is this possible? If so, how would I go about doing it?
Much appreciation ๐Ÿ™
Tags (1)
2 REPLIES 2
MagWeb
You can scale up by a factor using EDIT/Transform. Make sure UniformScaling is checked and set the factor in ScaleX(orY orZ) by clicking on the current value (1 by default).
This scales the wall thickness as well.
To get a different thickness ( fear this will result in gap between the outer and inner part) you would need to discard the interior surfaces and reconstruct it using SELECT>Edit>Offset.
Note: this model comes with a minimal number of long stretched triangles. You would need to SELECT/Edit/Remesh first to give it more density....
Think its much easier to rebuild that model with a different thickness from scratch with a BRep based application (like Fusion360)
Gunter Weber
Triangle Artisan
in reply to: MagWeb
Thanks for pointing me at select > Edit > Offset..., that appears to be approximately the right tool. But I guess the real answer is "rebuild this in Fusion 360."  Which is fine but now I have to learn how to use that tool as well. But ultimately I think that's what I want to know so a worthwhile investment.
Thanks!
