Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Repaired helper, help, and full localization to another language
1 REPLY 1
arhimedrus
168 Views, 1 Reply
Hello
I localized the program into Ukrainian. Also completely changed the links to the help (and helper) text files.
In my version, prompts for all possible commands are displayed.
For example, "Edit" - "Create Pivot":
mm_ima11
If you wish, you can translate these files into your native language.
With my version it will not be difficult. All files are external.
image_60
To get this result, I had to fix the "meshmixer.exe" file using the "x64dbg" program
mm_ima10
I cannot provide a direct link (prohibited by the rules).  If you are interested, you can find a link to my files if you enter the phrase in the "Google" search:
Meshmixer LookStailorX LSX3
1 REPLY 1
arhimedrus
in reply to: arhimedrus
I will add a little more.
There is a war going on in my country now. There is not always a connection, but light.
I will not be able to respond to your questions or suggestions in time.
And if you are Ukrainian, then it is better to write in the Ukrainian-language part of this forum:
https://forums.autodesk.com/t5/anonsi-spilnoti-zagalni/produkti-autodesk-z-ukrainskoi-lokalizatsieyu...
