Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Question about aligning 2 shells
6 REPLIES 6
skergeth
460 Views, 6 Replies
Hello MM Users,
i would need help again.
I have 2 scans of a finger (upper shell and lower shell)
I would need to align them exact and combine them as one object.
I could do that using the transfer tool but it takes time to shift the parts until they fit together exact.
Is there a way to set some marking points and tell meshmixer to align it together ?
Thanks for help 🙂
6 REPLIES 6
MagWeb
in reply to: skergeth
There's no point-pairs alignment in MM but there's selection based alignment in SELECT/Edit/AlignToTarget.
Let's say you want to align MeshB to fit to MeshA:
With MeshA active click the magnet in ObjectsBrowser to make it a target object > it turns to transparent blue. For a better view you might disable TransparentTarget in the View menu.
Now use EDIT/Transform to move MeshB to a roughly fitting position.
Now SELECT some overlapping regions on MeshB and run Edit/AlignToTarget. Hit ImproveSolution until MeshB doesn't move any more.
Gunter Weber
Triangle Artisan
skergeth
Thanks a lot 🙂
hfcandrew
in reply to: MagWeb
Couldn't you drop a pivot on each object on the same anatomical spot, then align pivot to pivot. Then rotate about that pivot for fine tuned adjustments.
skergeth
in reply to: hfcandrew
Hello Andrew,
i tried this but somehow it fails.
I did following steps:
> select shell A and drop the pivot (Settings: Surface point, Geometry frame, checkboxes disabled)
> select Shell B - same procedure
> with shell B active: edit / align (source + destination = pivot /  Translate only)
The alignment did not work and the pivot of the active shell was dislocated.
How to do it right ?
Thanks 🙂
hfcandrew
Can try this if you want to get super accurate: https://autode.sk/3nbFRZw
skergeth
Great !
Thank you so much !
