Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Problem with the preview, using the "Smooth" tool
4 REPLIES 4
josdomcas
537 Views, 4 Replies
Hello!
Sorry about my english, I formated my computer and after the installation I´m having a problem with Meshmixer 3.5 and 3.3 (the preview doesn´t appear usind the smooth tool).
4 REPLIES 4
MagWeb
in reply to: josdomcas
After you installed Windows:
Did you install latest drivers for your graphics card ?
Gunter Weber
Triangle Artisan
josdomcas
in reply to: MagWeb
I updated the drivers, but the problema persist.
When I open the file, in the beginning the selection tool is like this
and then it turns green:
MagWeb
Yep, I already saw that green selection issue in your first post. That's why I think it's a graphic card issue....
Never saw this until now.
Do you have two graphics on your computer ( maybe an onboard chipset and a decent card)? If so make sure that MM uses the more powerful (decent) device.
Did you try to drag another SHADER onto the object?
Did you try to set MM to BasicRendering (> Preferences/General-tab)?
Which Meshmixer version do you use? If you're on 3.5 try 3.3 instead.
Gunter Weber
Triangle Artisan
josdomcas
in reply to: MagWeb
Thanks for the answer!
Yes, I have 2 cards (notebook). I solved the problem reinstalling the Meshmixer (3.5) after updating the drivers.
