Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Problem: absence of meshmix icons display
1 REPLY 1
berny80
1070 Views, 1 Reply
Hi I have a small problem, I installed meshmixer 3.3, but when I try to look at objects in meshmix (primitives, arms, etc.) in the left column the list shows a series of red squares and I can't see the preview. how can i solve?
1 REPLY 1
MagWeb
in reply to: berny80
This is a known issue if the OS path to the meshmixer folder (by default you documents directory) contains some non Latin chars (chars not used in English language). In this case MM finds the part but not the preview images and replaces the missing thumbnails by a red square.
Most likely your user account on your machine contains such non Latin chars.
To fix (while MM isn't running):
  • either: rename your account
  • or move the whole meshmixer folder to a location "above" your account. On its next start MM will not find the needed folder and you get this dialog.Ohne Titel.jpeg
          Hit its Redirect button and browse the new location of the meshmixer directory.
Gunter Weber
Triangle Artisan
