Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Plane cut view
3 REPLIES 3
paulHNAV3
876 Views, 3 Replies
Plane cut view
I use to be able to see the cross-section when I would do a plane cut, why can I not see it now? hope this makes since.
3 REPLIES 3
MagWeb
in reply to: paulHNAV3
Check in Preferences whether BasicRendering is on. If so the Transparent SHADER doesn't work at all...
Gunter Weber
Triangle Artisan
paulHNAV3
in reply to: MagWeb
This worked thank you very much!
jfkdmd
in reply to: MagWeb
Thank you for this!!!
