Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
painting internal structure
1 REPLY 1
dgrosen
141 Views, 1 Reply
I want to create a dual color print of an anatomical model. I will print the model on transparent PLA and want to highlight an internal structure (blood vessels, nerve or particular bone) with a different bright color. Is there a way to paint or isolate this internal structure using Meshmixer?
1 REPLY 1
hfcandrew
in reply to: dgrosen
Yes. Select (select the outer area you want) > Edit > Separate > then paint each object as desired > select both items with shift + click > Combine > edit > Close cracks >Export
