Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Obtaining Inside of Stl File
6 REPLIES 6
arjunverma
864 Views, 6 Replies
Hi all, I have a 3d stl file of a human heart. The musculature is solid and the blood volume is empty. I'd like to 3d print the shape of the blood volume. any thoughts on how to do this with meshmixer (preferable) or other free softwares I can download. The file is attached.
6 REPLIES 6
MagWeb
in reply to: arjunverma
This DICOM result comes with many connections between the exterior and interior surface. These connections happen on the "ends" of the veins (which is correct) but also due to errors while meshing.
Basic workflow:
You need to break ALL those connections so you'll get the interior and exterior as non connected surfaces. After that you can EDIT/Separate both surfaces as separate objects. Now you need to SelectAll of the interior object, do Edit/FlipNormals and fix the holes using ANALYSIS/Inspector.
Best way to get rid of the exterior surface is to sample different SelectVisibles:
Go to SELECT.
Select some "seed" selection. Which selection doesn't matter - just to get access to selection based tools.
Navigate to a view where you do not see the interior surface through the outlet of the veins and run Modify/SelectVisible.  Now navigate to a different view (again where you don't see the interior) and with Shift pressed do Modify/SelectVisible again. This adds the new aspect to the previous selection. Repeat until you got the exterior selected.
When you selected most of the exterior without selecting the interior you might use the selection brush to add missed surfaces manually (or deselect while pressing CTRL (Cmd on Mac)).
Now hit Y to separate the exterior and hide it via ObjectBrowser's eye icon (against deleting the surface this gives the chance to transfer regions back if you didn't select properly)
With the interior object being active hit Ctrl+A (Cmd+A on Mac) to SelectAll and run Edit/FlipNormals.
Now fix the holes via ANALYSIS/Inspector:
This result is attached below.
Gunter Weber
Triangle Artisan
hfcandrew
in reply to: MagWeb
I did sort of the same thing but used about dozen or so times of generating face groups to delete chunks at a time, then finished the rest at each artery opening by hand. See attached for a hollow version created using offset.
arjunverma
in reply to: hfcandrew
i tried both of these methods and they worked! thank you both very much!
mraihawi
mraihawi
in reply to: MagWeb
Hey, which Software did you used, that your Segmentation empty from inside, because when i cut the heart in Meshmixer i can see the reality edges for the ventricle and the atrium
MagWeb
in reply to: mraihawi
Only Meshmixer was used. And the workflows explained above should work just fine.
Gunter Weber
Triangle Artisan
