Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Newbie: Please help with selection tool working
2 REPLIES 2
deonholt
336 Views, 2 Replies
Hi and thanks so long for your help.
I have just started using Meshmixer. I am watching this video on selection: https://youtu.be/xw_ClxnJ1_U?t=433
But, I cannot seem to get a round brush selection tool. This means I cannot clearly see what I have already selected. I attached a screenshot of what I mean. My selection tool does not show as a brush but as this neon green rectangle which I cannot seem to control.
If you can point me to a tutorial that'll be great.
Secondly, how do I keep claw #1 selected while painting the other? I want to group them together.
TIA.
Labels (1)
2 REPLIES 2
MagWeb
in reply to: deonholt
Seems to be some rendering issue. Did you already try to update your graphics card drivers ?
If updating the graphics drivers does not solve it you might try:
- Install Meshmixer 3.3 instead of 3.5 (get it from the download page of Meshmixer.com)
or:
- Some rendering issues are related to the ViewCube. You can disable ShowViewCube via MM's Preferences (menu) in its View section on its General tab.
or :
-  Enable BasicRendering (> Preferences>General>View). This option is bad as it does not allow transparent rendering which is used in certain tools (e.g. EDIT/Hollow...).
@Anonymous multiple areas
If you use the brush (which doesn't work for you) to select several areas: Simply use the brush to paint paint areas orange.
If you use the laser selection (click on empty space to get a red line to the next click...until you get a loop) a new selection will discard the previous. If you do a second while pressing Shift, it will be added to the previous selection.
Gunter Weber
Triangle Artisan
deonholt
in reply to: MagWeb
Thank you very much for getting back to me. I will try according to your suggestions and get back.
Thanks again.
