Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Need Help with Plane Cut and Separate Shells
1 REPLY 1
ax_al18
201 Views, 1 Reply
Hello, im having an issue whem plane cuting. i need to plane cut several objects in a 30° that i need as separate parts. but the only solution i find is combinig the parts wich leads to all the parts being one. is there any way to do this?
The parts are 4, Shell, interior, windows and floor panel
Thanks!
Axel
1 REPLY 1
hfcandrew
in reply to: ax_al18
Edit>Drop Pivot
Set the pivot to 30°
Start the plane cut tool, then click on the pivot to snap it to the pivot, repeat for each object.
