Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Need help with exporting complex stl
12 REPLIES 12
Message 1 of 13
3181 Views, 12 Replies
I have a basic triangle with 4 smaller triangles on top of the base triangle. Making the face groups seem to work fine and making the complex and splitting the complex seems ok but when I go to export it, it does not show the STL Binary that groups it all together, just the basic STL Binary format.  I am trying to make multi STL from 1 STL so I can print the different areas into color using the Mosaic Pallet 2 pro.
12 REPLIES 12
Message 2 of 13
MagWeb
To export a complex as a sequence of files you need to export the complex object NOT the split parts.
Gunter Weber
Triangle Artisan
Message 3 of 13
in reply to: MagWeb
I have already tried that but same problem. the option of "STL Binary sequence, One File per Region (*.stl)" is not there?
Paul
Message 4 of 13
MagWeb
Hmm, which version of Meshmixer do you use?
Just to make sure:
1. Activate the object with the (complex) index in the ObjectBrowser
2. Click on EXPORT
3. Expanding the export formats options (this screenshot was done on macOS) you should see the sequence options...Ohne Titel.jpeg
Gunter Weber
Triangle Artisan
Message 5 of 13
in reply to: MagWeb
I am using V 3.5.474  This is my screen after clicking export. how every the STL Binary Format is all I get as far as exporting the STL Binary.
Message 6 of 13
Here is what I see in the save as box:
Message 7 of 13
MagWeb
Hmm, no clue about what is happening here... Maybe some WIN incompatibility???
So I can't give you a better advice but to run EDIT/SplitComplex and to Export the resulting objects one by one as a  STL.
If you export to the same directory the result will be the same....
Gunter Weber
Triangle Artisan
Message 8 of 13
mykolka
in reply to: MagWeb
This is definitely a bug. I can't export STL sequence too. I'm on win 10
Will try another software...
Message 9 of 13
MagWeb
in reply to: mykolka
@mykolka
Don't know any software to handle MM complex objects. Actually such objects are using non manifolds.
Maybe you're doing something wrong in the Complex tool:
After accepting GenerateComplex: Does the something(complex) object show any green lines like this:?
Note: You can get a "complex" object if you never generated complex surfaces (e.g. by accepting GenerateComplex without doing anything inside the tool).
E.g. the upper example looks like this:
In this case there are no sequence options on export.
Gunter Weber
Triangle Artisan
Message 10 of 13
mykolka
in reply to: MagWeb
Cura did the trick for me (with a plugin). Splitted complex scene into separate objects.
Message 11 of 13
MagWeb
Interesting!  - Which Cura plugin?
Gunter Weber
Triangle Artisan
Message 12 of 13
mykolka
in reply to: MagWeb
Mesh Tools -> Split model into parts
Message 13 of 13
MagWeb
Thanks, good to know!
Gunter Weber
Triangle Artisan
