Hello, I find the "hollow" function of Meshmixer is very nice, and this tool can create holes for the object.
I also want to obtain the stl file of the created hole, but I failed after trying many times.
If I subtract the bunny model with the hole from the original bunny model, something wrong happened...This calculation took a long time and gave me a wrong file (see figure below)
It looks like the two bunny models did not perfectly match, which resulted in a lot of pieces being generated on the surface.
Can someone tell me how can I obtain the stl file of the hole created by the "hollow" function? I want to print the bunny and the hole separately and assemble them together.
Thank you in advance.😀
