Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Need help cleaning this scan
5 REPLIES 5
hfcandrew
398 Views, 5 Replies
I have this scan of a foot, it is non-manifold, and the main surface of the foot is fine with correct normals, but higher up the sides of the foot the normals are flipped incorrectly, non-manifold, and there is a 'seam' but it is connected at several points, so the whole file is just one shell.
Can I get some help welding the boundaries, all the tools and function (Bridge, Join, Weld Boundaries) keep failing on me. Thanks!
5 REPLIES 5
MagWeb
in reply to: hfcandrew
When you do EDIT/GenerateFaceGroups at defaults it generates two main groups and many tiny groups:
Select the flipped main group by double click and run Edit/FlipNormals. Select that group again and Separate it hitting Y.
Select the main group at the sole object and manually add the missed groups at the toes. Invert this selection to select the messy stuff and discard it.
You should end up with something like:
Now go to SCULPT and use a smooth brush to polish the "contact boundaries" on both parts:
Combine both parts and use SELECT/Edit/Bridge to create some connections between the shells.
In ANALYSIS/Inspector click the spheres pointing to interior issues (you don't want to close the outer boundary)
We smoothed the seams with SCULPT. This might have deformed the scanning result. We need to make sure that the fixed result still fits to scan.
So append the source mesh to the scene once again and set it as a target clicking the magnet in the object browser (the source mesh should be transparent blue now).
SelectAll of the fixed mesh and run Edit/AttactToTarget:
Fixed:
Gunter Weber
Triangle Artisan
hfcandrew
in reply to: MagWeb
Thanks MagWeb. You are so good at MM haha! Okay, I almost got it.
The inspector tool keeps failing, so I tried discarding more triangles at the messy points, and cut off the toes too as I don't need them for this task and also added more bridges but still not working.Inspector fail.png
MagWeb
If open boundaries are to close together (means there are not enough triangles between the boundaries) MM can't handle non manifold repairing. On your image you see the red faces reach from one boundary to another so the different holes are treated as a single issue.
So create the bridges "wider" and increase the mesh density (SelectAll > EditRemesh  with Density above zero%)
Gunter Weber
Triangle Artisan
hfcandrew
in reply to: MagWeb
Yep you got it! And ended up using the refine brush on some of the fail points which were located at the bridges:
And I actually figure out a second way to do it using erase and fill:Erase and fill - Final.png
Thanks so much again! And my patient thanks you too because now I don't have to have her book time off work just to come back in for an appointment to be rescanned!
   - Andrew
MagWeb
You're welcome.
And yep, many roads lead to Rome.
Gunter Weber
Triangle Artisan
