Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Model "disappears/greys out" when I angle it to look at bottom
2 REPLIES 2
glaevsky
680 Views, 2 Replies
Hi All,
Super newbie, but fairly intelligent.  Greatly appreciate the help and patience in advance!
I bring in an stl from skanect. I’m trying to look inside the shell to separate layers and pick what I need. When I angle image to look “underneath ,” it greys out, and if I keep angling it, then the palette goes blank. When I reduce the angle, the image comes back. ?
COVID is giving me way too much time, so learning new things.  Super appreciative of any help I can get!
Gary
2 REPLIES 2
MagWeb
in reply to: glaevsky
Not sure what you're doing exactly...
So some hints:
- Might be a graphics card issue? > Make sure that you're using latest drivers available for your card. Check if there's some update available.
- Might be caused by the nearby "clipping plane". If you zoom in all stuff nearer than a certain distance isn't rendered. You might define another clipping plane distance this way: In SELECT paint a small area orange to select it. Now do menu View/RecenterView.
- Maybe the Printer's base hides the object? You can turn of rendering of the printer via menu View/ShowPrinterBed
If that doesn't solve your issue: Please post a screenshot.
Gunter Weber
Triangle Artisan
glaevsky
in reply to: MagWeb
It was the zoom.  Thank you!  See you soon .... argh ....
