Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
MMAPI model - tool manipulation
3 REPLIES 3
mc_rees
620 Views, 3 Replies
Hey ppl!
I 'm trying to do some stuff through mmapi. Let's say I want to move a model or use a tool like plane cut. I can do rotations (create rotational matrix, etc) and I can do relative translations (a percentage of height, width etc).
What I cannot do, is input world distances to these tools, eg move plane cut by 2 mm, or translate model by 3mm.
Anyone know how I could do it?
Tags (1)
Labels (1)
3 REPLIES 3
hfcandrew
in reply to: mc_rees
Ya turn on snap step and absolute coordinates. Read the positioning before, then move it in XYZ by your reading + 2mm etc.
MagWeb
In case of Transform tool: Moving an object 3mm in X to negative:
import mmapi
from mmRemote import *
import mm
remote = mmRemote()
remote.connect()
mm.begin_tool(remote, 'transform')
mm.set_toolparam(remote, 'translationWorld', (-3.0, 0.0, 0.0) )
#mm.accept_tool(remote)
remote.shutdown()
In case of PlaneCut you need to define the origin (some point on the cutting plane) of the tool instead (don't forget to convert World to Scene coordinates). This cuts 5mm above world origin:
mm.begin_tool(remote, 'planeCut')
pos = mm.toS(remote,(0.0, 5.0, 0.0))
mm.set_toolparam(remote, 'origin', pos)
Gunter Weber
Triangle Artisan
mc_rees
in reply to: MagWeb
Thank you people!
It worked. I had to change one line, as to @MagWeb's example. I also took @hfcandrew's advice and eyeballed my distances by activating Snapping.
Thank you so much! I literally had thrown hours at this!
Technology Administrators
