Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
MM api import Mesh
1 REPLY 1
nmhoogeweg
177 Views, 1 Reply
MM api import Mesh
Hi!
I want to automatically import a mesh / append a mesh to my object list by using the following code:
import os
import mmapi
from mmRemote import *
import mm
remote = mmRemote()
remote.connect()
CYL_5_3 ='cylinder_5_3.obj'
mm.scene.append_objects_from_file(remote, CYL_5_3)
But nothing happens and I also don't get an error message. I've tried the cylinder file as an obj. stl. and mix. document, but this doesn't matter.
Could someone help me? Thanks in advance! @MagWeb
1 REPLY 1
MagWeb
in reply to: nmhoogeweg
Using relative paths there are some strange things happening on certain file names.
Assuming a .obj in the same directory as the .py this works:
import os
import mmapi
import mm
remote = mmRemote()
remote.connect()
CYL_5_3 ='test.obj'
While this doesn't:
import os
import mmapi
import mm
remote = mmRemote()
remote.connect()
CYL_5_3 ='cylinder.obj'
 No idea why...
Using full paths instead works fine.
Gunter Weber
Triangle Artisan
