Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Meshmixer run batch file
1 REPLY 1
thong.dv2
618 Views, 1 Reply
Hi, I have an question
I installed Autodesk meshmixer on windows OS,
I want to fix overlapping STL file by the tool meshmixer (by solidification tool). Once it is fixed I want to print the STL file using 3D printer.
I also want to use command line (running batch file) to do this task automatically. I wonder whether it is possible, and if yes, how to do it.
It means :
1. I have a list of STL files in one specific folder
2. I will create a batch file (.bat) to import each STL file in folder (using queue) into meshmixer tool, then run overlapping fixing tool in meshmixer with a certain preset configuration.
Could anyone help me with that ? Thank you !
1 REPLY 1
MagWeb
in reply to: thong.dv2
There's no such batch interface in a MM release but there is mmApi allowing to loop on all mesh files at a certain path using Python scripting.
This is no code but basic steps:
# generate a list of source files
# process each item in that list in a loop:
## mm.append_objects_from_file(remote, filename)
## (some tool commands)
## mm.export_mesh(remote, path)
Gunter Weber
Triangle Artisan
