Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Meshmixer not loading!
3 REPLIES 3
eniye9
895 Views, 3 Replies
Working on a project and Meshmixer randomly froze. Restarted my laptop and since the restart the application is not opening or responding. I have uninstalled and reinstalled it numerous times. Can anybody help? Thanks in advance.
3 REPLIES 3
MagWeb
in reply to: eniye9
If MM did its job before you might try this while MM is down:
Delete the autosave folder (MM will create a new one at its next start):
If you did a standard installation the auto-save file is usually located here:
Windows: C:\Users\User Name\Documents\meshmixer\autosave
Mac: ~/Documents/meshmixer/autosave
And or:
Delete or rename  meshmixer.ini (MM will create a new one with default settings at its next start):
Windows: C:\Users\User Name\AppData\Roaming\Autodesk\meshmixer.ini
Mac: ~/.config/Autodesk/meshmixer.ini
(NOTE: AppData as well as .config is hidden by default, so you might have to enter that path manually or choose to show hidden files.)
Gunter Weber
Triangle Artisan
paper1pr
in reply to: MagWeb
I had to create an account just to thank you, I would have never figured this out on my own. It's been months since my meshmixer worked, deleting "meshmixer.ini" worked like a charm. Thanks so much!!!!
hezha_shafiq
in reply to: MagWeb
Thank you so much you saved me
