Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Meshmixer master! I need help with export
2 REPLIES 2
skeepe10
347 Views, 2 Replies
I have a question. In the meshmixer program, I merge two 3d objects with textured (form - .obj) -> I export, but as a result, the composite object is decomposed into two objects and two textures. What am I doing wrong? I apologize for my English
Thanks for the information,
Petr
Labels (1)
2 REPLIES 2
hfcandrew
in reply to: skeepe10
What did you mean by 'merge'? That is not terminology used in MM. Perhaps did you use a 'combine' operation, or a 'boolean' operation?
skeepe10
in reply to: hfcandrew
Hi, I used the "combine" operation.
Thank you.
