Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Meshmixer in German
2 REPLIES 2
Unbenannt
2296 Views, 2 Replies
Meshmixer in German
Is there a possibility, to change the language from Meshmixer into German?
Thanks.
2 REPLIES 2
MagWeb
in reply to: Unbenannt
Basically you could do the hack I'd post for Chinese here:
Change language to Chinese
With QtLinguist you can edit the .qm translation tables to any language you like.
Since there's language support I'm considering a translation to German and already tried to do it. But does it make that much sense? There are many CG terms where one fails to find a German equivalent being short enough to be displayed in the GUI properly and some are simply CG jargon. Also it's much harder to give support dealing with several language versions...IMO it's better in most cases to stick with the English version and learn the CG jargon if one is able to read latin chars.
But if you really need a German version, e.g. for educational purposes, I'd be willing to help.
Gunter Weber
Triangle Artisan
Unbenannt
in reply to: MagWeb
Okay, I think QtLinguist helps me a lot. Thank you!
