Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Meshmixer Crashes
27 REPLIES 27
Message 1 of 28
9639 Views, 27 Replies
Meshmixer Crashes
When I select the export to Meshmixer option under the save as STL menu Fusion will launch Meshmixer, Meshmixer will open and the part will appear in the build area but then I get a Windows notification that Meshmixer has crashed.  Tried this several times. Close Fusion and relaunched, same results.  Windows 8.1 system, fresh install of Meshmixer.
27 REPLIES 27
Message 21 of 28
rms_adsk
Did you try deleting the .ini file I mentioned in my post?
Ryan Schmidt - Autodesk Research / Design & Fabrication Group - Creator of Autodesk meshmixer
Message 22 of 28
When i reinstalled meshmixer to fix a fail to launch issue, i had to "manually" erase any meshmixer data. since the uninstall app leaves unwanted files behind.
So after uninstalling, system search meshmixer and delete anything that isn't a project, before reinstalling.
I tried reinstalling like 20 times and updated every driver before i thought of this! hope it helps.
Message 23 of 28
Still same problem
Message 24 of 28
My device
 im doing all of things but still facing crashing problem
 what should I do next
Message 25 of 28
Warmingup1953
I believe Meshmixer is (effectively) Abandonware. Do you have an ongoing requirement or is this simply a one-off (or close) need? Can you share the file you need assistance with and your aims/needs?
Message 26 of 28
christian.tapkenKLE4M
Message 27 of 28
hfcandrew
in reply to: Warmingup1953
was this meant to be a reply to a thread elsewhere?
Message 28 of 28
That was a mistake in moving threads and posts. It has now been sorted out, thread and responses are now back together, and the thread itself in the appropriate forum, too.
Steffen Anders
Autodesk Netfabb Team
Netfabb resources: Online HelpNetfabb knowledge baseForumsHomepageYouTube
