Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Meshmixer Crashes
Meshmixer Crashes
When I select the export to Meshmixer option under the save as STL menu Fusion will launch Meshmixer, Meshmixer will open and the part will appear in the build area but then I get a Windows notification that Meshmixer has crashed.  Tried this several times. Close Fusion and relaunched, same results.  Windows 8.1 system, fresh install of Meshmixer.
Replies (27)
rms_adsk
Did you try deleting the .ini file I mentioned in my post?
Ryan Schmidt - Autodesk Research / Design & Fabrication Group - Creator of Autodesk meshmixer
When i reinstalled meshmixer to fix a fail to launch issue, i had to "manually" erase any meshmixer data. since the uninstall app leaves unwanted files behind.
So after uninstalling, system search meshmixer and delete anything that isn't a project, before reinstalling.
I tried reinstalling like 20 times and updated every driver before i thought of this! hope it helps.
3dmistryhomedecor
Observer
Observer
Still same problem
3dmistryhomedecor
Observer
Observer
My device
ā€ƒim doing all of things but still facing crashing problem
ā€ƒwhat should I do next
Warmingup1953
I believe Meshmixer is (effectively) Abandonware. Do you have an ongoing requirement or is this simply a one-off (or close) need? Can you share the file you need assistance with and your aims/needs?
hfcandrew
was this meant to be a reply to a thread elsewhere?
steffen_anders_adsk
Autodesk Support
Autodesk Support
That was a mistake in moving threads and posts. It has now been sorted out, thread and responses are now back together, and the thread itself in the appropriate forum, too.
Steffen Anders
Autodesk Netfabb Team
Netfabb resources: Online Help ā€¢ Netfabb knowledge base ā€¢ Forums ā€¢ Homepage ā€¢ YouTube
