Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Mesh to thick shell
3 REPLIES 3
404 Views, 3 Replies
Mesh to thick shell
First off I am n00b in mesh manipulations and in Meshmixer. I am just 3d printer hobbyist. I appreciate any help.
I had STL that I divided into more bodies so I can print them. However, I want to make them hollow so I can place electronics inside. And now I am stuck. What are the next steps?
This is one of the bodies that I want to make about 1-2 mm thick like a shell, then, want to make holes in it for the buttons and print it.
What are the next steps? any suggestions? Thank you in advance.
3 REPLIES 3
hfcandrew
I'm always bad at understanding what someone wants. But this sound like it will involve offsets.
Probably something like:
  1. EDIT > GENERATE FACE GROUPS
  2. SELECT the faceS you want removed
  3. DELETE
  4. SELECT ALL > DEFORM > OFFSET (2MM)
MagWeb
Think the easiest way would be to do EDIT/Hollow first an do the cutting after that.
Gunter Weber
Triangle Artisan
in reply to: hfcandrew
thank you.. this helped a lot.
Thank you again.
