Mesh always transparent when imported
hgmrizzo
Observer Observer
hgmrizzo
Observer
Observer
hi!
i'm having a problem importing .stl
it always appears transparent
I've tried various configurations with no results...
i've uninstalled and reinstalled the software and it's still there
can anyone help me with this?
Thanks in advance!
hfcandrew
Is it the same .mix project file you are working on?
Working with SHADERS there are two ways to apply them to a scene or a specific object:
  1. Dragging a SHADER material onto a specific object applies it to that very object
  2. Dragging a SHADER material onto empty space applies this material to all object which do not own a specific shader done via way 1.
MM remembers the second way - the shader for all objects without a specific shader - in meshmixer.ini
So if you accidentally dragged the XRay shader onto empty space: All new objects will appear transparent until you drag a different shader onto empty space.
A new installation does not refresh meshmixer.ini...
hgmrizzo
Observer
Observer
it worked, my friend! thank you very much!
