Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Mesh always transparent when imported
3 REPLIES 3
hgmrizzo
312 Views, 3 Replies
hi!
i'm having a problem importing .stl
it always appears transparent
I've tried various configurations with no results...
i've uninstalled and reinstalled the software and it's still there
can anyone help me with this?
Thanks in advance!
3 REPLIES 3
hfcandrew
in reply to: hgmrizzo
Is it the same .mix project file you are working on?
MagWeb
Working with SHADERS there are two ways to apply them to a scene or a specific object:
  1. Dragging a SHADER material onto a specific object applies it to that very object
  2. Dragging a SHADER material onto empty space applies this material to all object which do not own a specific shader done via way 1.
MM remembers the second way - the shader for all objects without a specific shader - in meshmixer.ini
So if you accidentally dragged the XRay shader onto empty space: All new objects will appear transparent until you drag a different shader onto empty space.
A new installation does not refresh meshmixer.ini...
Gunter Weber
Triangle Artisan
hgmrizzo
in reply to: MagWeb
it worked, my friend! thank you very much!
Technology Administrators
