Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Merge objects with cut
3 REPLIES 3
eric5HPME
4973 Views, 3 Replies
I have a few little figures as STL files that I would like to use as little card holders, like you would see as a name tag for a wedding, etc. Is there a simple way in Meshmixer to take a little object, like a thin cube and "cut" into the existing STL file, like you would do with the combine -> Cut command in Fusion 360?
Thanks!
3 REPLIES 3
MagWeb
in reply to: eric5HPME
You can use BooleanDifference to cut into your object A:
-Import object A;
-From MESHMIX/Primitives drag the cube to empty space on your scene. This gives a new object B which you can use to subtract it from A. Use Transform (called automatically when you drop the part) to scale and position it. Accept;
-Click on object A to activate it. Now hold down Shift and click on object B to make it active too. Note: this order is important as you want subtract A-B.
-The options in EDIT changed and you will find BooleanDifference there. Run it...
Gunter Weber
Triangle Artisan
eric5HPME
in reply to: MagWeb
Outstanding, thank so much!
cbellerose81
in reply to: MagWeb
awesome bud, this helped me cut away a 3d scan of my face from the same 3d scan of my face to help me make a mask of myself that is perfectly fitted to me.
