merge/combine 3 stls into 1
Hello all. I have a set of 3 stl files that are in a specific arrangement, and i want to know if meshmixer can combine them into one stl file. basically, merge them into a solid?
thanks
hfcandrew
Yes it can.
Shift+click each one, then select 'Combine'. Then export it.
that was fast haha. ok, i will try it out now and see if it works. Is there a way to make sure it creates a "solid" with no errors?
ok, i tried it, and now each piece is a different color. What does that mean?
thanks
hfcandrew
The colours are facegroups
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-75A13050-FE81-47D1-A4F3-C2B2BF7087D0
To make it watertight (solid)
Edit>Make solid
