Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
mating system creation by using boolean difference
1 REPLY 1
park2792
121 Views, 1 Reply
Hi!
I need to create a mating system that allows two objects to be combined as you can see the attached image. I used the male piece by using "combine function", but the female part should be bigger than the male piece. Do I have just to increase the female volume with "Transform"? Or Is there any adjustment in boolean difference?
1 REPLY 1
fred_dot_u
in reply to: park2792
When you create the male piece, duplicate it in place, then transform/scale it as desired and use the larger duplicate to subtract the volume for the female piece.
