Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Make Solid tool creates negative dimensions
1 REPLY 1
j2samodal
191 Views, 1 Reply
I am trying to refine a mesh using the make solid tool. The tool preview is transparent and the resulting solid has dimensions of -3.402mm. Messing with any of the tools settings doesn't change the result. The refine brush on the sculpting tool does nothing to it. All the other meshes in the file work just fine even though they were cut from the same parent mesh
1 REPLY 1
hfcandrew
in reply to: j2samodal
Not sure. Post your .mix of this.
Also if you want to refine a mesh, just use remesh, not make solid.
