Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
low poly not work
2 REPLIES 2
stfn77
417 Views, 2 Replies
low poly not work
hi guy i try to , repeat  this  simple tutorial https://www.instructables.com/id/Create-Low-Poly-Art-from-3D-Models/
for  have a  bunny in low poly , i select the 3D model , with  s + double click over , go in edit , reduce , and  reduce percentege , tri count ,and max deviation but , return me a bunny-egs  , not low poly , someone  can help me ??  thankz at all
2 REPLIES 2
hfcandrew
in reply to: stfn77
Ya all that should be working.
Hit 'W' to bring up the wire frame to more easily inspect what the triangles are looking like. Also fyi it should update and change as you modify the setting in the 'Reduce' menu. If nothing is occurring at all, then some strange bug is going on. Try it on any other shape an see what happens.
stfn77
in reply to: hfcandrew
thankz  for Replay , i use  w  and  i saw   a structure now  is ok i suppose
when i reduce , yes of course  reduce  but  color  is different  than tutorial but  i suppose with w is ok
thankz  again
