Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Loft irregular surface to cylinder
3 REPLIES 3
priyanairQQM4M
384 Views, 3 Replies
I am working on creating a model of a blood vessel for 3D printing. In order to be compatible with connectors for tubing we will be using, I want to create a extended and enlarged portion of the vessel. The edge of the vessel inlet is flat but an irregular shape. Is there a way to loft to a larger diameter and in a way that the final surface will be a concentric circle (cross section of a cylinder) while keeping the surface smooth?
Attached a screenshot of what I'm picturing it to look like.
Thanks!
3 REPLIES 3
hfcandrew
in reply to: priyanairQQM4M
Yes. Select the bottom couple of millimeters then > Modify > soft transform
priyanairQQM4M
in reply to: hfcandrew
Thanks for your quick response! Is there a way to prescribe the final diameter of the extended portion instead of a trial and error with the transform?
hfcandrew
Yes, click on the S to turn on snap step, then you can warp it by the millimeter
