Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Issue Converting SLA/DLP Supports to Solid - Not Connecting to Mesh
1 REPLY 1
benL55T4
368 Views, 1 Reply
Hey everyone!
I've been having an issue since I installed MeshMixer. Whenever I generate supports for a mesh and use the "SLA/DLP" preset, everything works fine at first. However, when I convert those supports to a solid, then none of the supports connect to the mesh, and they even seem to avoid the mesh as if it had a force field around it. It's easiest to show this on the miniatures I'm trying to print, but it happens on every mesh I can import, including the default ones.
I've already tried:
  • Reinstalling MeshMixer 3.5
  • Installing MeshMixer 3.3
  • Installing MeshMixer 3.3 and 3.5 on a different computer (Both are Windows 10)
  • Restarting/Updating my computers
  • Messing with every setting individually
  • Choosing "New Object" and "Replace Existing" when deciding how to convert the supports
Is there something I can do to fix this issue or at least work around it?
Mesh Converted Supports.PNGMesh Supports Zoom.PNGMesh Converted Supports Zoom.PNG
1 REPLY 1
MagWeb
in reply to: benL55T4
Most up to date SLA/DLP slicers handle MM's raw supports just fine. Please check if you really need to convert the raw supports to a solid support.
Making supports solid in Overhangs MM merges the different support elements based on a certain voxel grid which may smooth small stuff as the supports' tips. You might get a better solid result accepting the raw supports, separating them as a separate object and running EDIT/MakeSolid on it with a higher SolidAccuracy and MeshDensity at file size costs.
Gunter Weber
Triangle Artisan
