Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Importing and orientation
2 REPLIES 2
paulHNAV3
834 Views, 2 Replies
When I use to import meshmixer would import in the orientation I saved the file. Now when I import it's in a totally different orientation, is there something wrong with the way I have my preferences?
2 REPLIES 2
hfcandrew
in reply to: paulHNAV3
Maybe.
Look under preferences to flip Z-Y on export/export.
MagWeb
Most likely you're facing the different Up conventions issue. Construction CAD applications (coming from extruded 2D floor plans where X and Y were used as the horizontal plane) use Z as the third and therefor up-dimension. There are other more artistic applications where 3D started from a vertical image on a monitor (here the monitor's width X and height Y is thought to be a vertical plane). Here Z is the depth and therefor the XZ plane is the horizontal plane while Y is the up direction.
MM uses Y as the vertical dimension. So if you import an object you did in a Z-Up application it appears rotated 90° (oriented horizontal instead of vertical). Same if you export from MM and import to a Z-up app (as most machining softwares which are Z-up)
EDIT: Andrew is typing faster 🙂
For easier handshake there's an option in the Import dialog (and in Preferences) to flip Y/Z on Im/Export. Check this setting and your source/target application which Up direction is used.
If you're facing a different issue please recall - maybe some image?
Gunter Weber
Triangle Artisan
