Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
I want to increase the partial mesh differently for each axis.
3 REPLIES 3
park2792
192 Views, 3 Replies
I need to stretch the finger (as you can see the middle part of finger and diagram) differently for each axis. But I should keep the all finger direction as original. How can I do this?
3 REPLIES 3
hfcandrew
in reply to: park2792
On Local vs World frame, one axis of the transformation widget should be automatically aligned to the longest axis of your model. In your screen shot you are on 'L' but this occur. This is a common bug with MM, happens all the time, I've never been able to figure out when or why this happens.
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-23DF16CC-64E0-4399-A271-867A3A146207
Sometimes closing and reopening MM fixes this. If you doesn't you can manually reset your widget axis by dropping a pivot on the object and moving it into the orientation you want, then doing the transform with snap step on set to 1mm.
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-EDB35D1E-13EB-4689-A83E-DD8C1D71CDC2
See video:
MagWeb
in reply to: hfcandrew
LocalFrame is generated along the world axes at the moment the object was generated/imported/separated.
Instead  WorldFrame it travels along with the object's rotations.
Gunter Weber
Triangle Artisan
MagWeb
Instead == Against
Gunter Weber
Triangle Artisan
