Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
I really want to fill the hole.
5 REPLIES 5
park2792
237 Views, 5 Replies
This is my mesh and I'd like to fill the hole with flatfill at the bottom of mesh, but when I attempt to go to analysis for inspect, it has many gaps as you can see, but it doesn't point the area I'd like to fill. How can I fill the hole at bottom??Screenshot 2024-03-02 at 10.01.44 AM.png
5 REPLIES 5
fred_dot_u
in reply to: park2792
if you don't have any NDA considerations, attach the mesh or the .mix file
park2792
in reply to: fred_dot_u
I attached it!
fred_dot_u
One might think I cheated, but I've found that Windows 3D builder has an amazing repair feature. I opened the hand, allowed the repair and the result is attached.
It passes the Meshmixer inspector and other than unusual treatment between fingers, looks pretty clean.
One observation, though. The mesh count is rather high and could stand some reduction, if for no other reason than to reduce the processing load on the slicer.
park2792
Thank you Sooooooooooo much! You save my life!
hfcandrew
Ya windows 3d Builder is amazing. but fyi MM can do this fine too. Just first go Edit>Close Cracks, then run inspector.
Scanned .obj's often need cracks closed first.
