Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
I need to combine mesh bodies into one body with no cracks.
1 REPLY 1
sarah7GNPA
406 Views, 1 Reply
I have a model of a man that is broken into many different pieces.  As you can see in the photo, there are gaps and cracks between the pieces.  Is there a way to connect all of these together and fill in all the gaps/cracks with a new surface.  I want it to be one pieces so I can smooth it out, and edit the form as one unit rather than separate pieces.
1 REPLY 1
hfcandrew
in reply to: sarah7GNPA
Yep this is a common workflow needed in scans.
Yep, read this: https://forums.autodesk.com/t5/meshmixer/patching-up-holes-located-on-edge-of-scan/td-p/9408159
and Read this: https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-586B1E54-9309-421B-9CF9-62CC417D8CDC
Watch this: https://www.youtube.com/watch?v=7nkGreGUsFY&t=42
Essentially do this 50 times in all the various corners: SELECT (where you want your bridge to be)>BRIDGE>ANALYZE>INSPECTOR
Hint: It helps sometimes zooming in and hitting 'w' to see which exact triangles you want to bridge. And then also if inspector produces poor/unexpected results, often the mesh density is too low around the border, so remesh it higher. Also once you are done, use the various sculpt tools to smooth spots out.
