Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
I created a hole with my main object, a cylindar and boolean difference but the end result is off
3 REPLIES 3
johnostler
212 Views, 3 Replies
Hello all. I created a hole in my main object, a cylindar and boolean difference but the end result is off. when i click my main object then hold select and click my cylindar that is running through my main object a menu pops up and i click boolean difference. Then a loading bar runs and it does work. A hole is made straight through my object and it looks perfect. The problem is when I click accept to finalize the changes. That hold then becomes filled in. I think it may be because my main object has infill. How do I do this and keep the hole a hold and stop it from getting filled in? thanks.
3 REPLIES 3
hfcandrew
in reply to: johnostler
Booleans are random and finicky, just play around with the parameters trying a dozen different things until it works.
johnostler
in reply to: hfcandrew
Thanks for the advice I will tinker with this a see how it goes. If I cannot figure It out maybe I will post some pics. Thanks.
MagWeb
Likely this is related to  auto-reduce MM does accepting the preview.
You might simply disable AutoReduceResult in the tool's options totally
or
decrease TargetEdgeScale
Gunter Weber
Triangle Artisan
