Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
I can't generate face groupe any more!?
2 REPLIES 2
alexandre.pfister
523 Views, 2 Replies
2 REPLIES 2
MagWeb
in reply to: alexandre.pfister
Seems MM is set to render surface color (per vertex color) instead of groups.
To switch to group rendering:
Press and hold Space on your keyboard to open the Hotbox.
In its Color section are two buttons: One with a blue gradient (this is surface color rendering) and one with a green area(face group rendering). The darker one is active...
Another way is via Preferences/General-tab > MeshColorMode should be set to GroupColor
Gunter Weber
Triangle Artisan
Thanks a lot Gunter!
