Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How to slice a object uneven (not plane cut) ?
6 REPLIES 6
skergeth
3405 Views, 6 Replies
Hello to all,
i am using meshmixer since a few month and it is a great tool for working.
I would need to cut the edges along of a object but can not use the 'plane cut' tool from the edit menue because it's not a plane Surface.
I would need something where i can mark Points step by step along the Surface and then cut it after the complete Edge.
Is there a function likethis in meshmixer ?
Thank you for helping 🙂
6 REPLIES 6
hfcandrew
in reply to: skergeth
Yep.
SELECT the surface you want > EDIT > SEPARATE
This will separate your selection off of your original part and create it as a new object in your object browser. If you don't like the jagged edges of the triangles, then before you separate it go MODIFY>SMOOTH BOUNDARY
skergeth
in reply to: hfcandrew
Hi Andrew,
thank you for Reply.
Ok, but how can i mark the area i want to remove before i use 'separate' command ?
For practice example:
I have  a insole and want to cut the the Edge around before i convert it to a milling file.
With the 'plane cut' tool i can not do this because it's all curved.
hfcandrew
This is a process I do daily with my orthotic design and millings. I'm not quite following what you want done. Can you elaborate and post the .mix and do a screencast or post pictures.
skergeth
Hello Andrew,
i was attaching a screenshot because the .mix file is too big for attaching.
I was designing a pair of insoles and want to cut / trimm the edges upside before i mill the insoles.
See red lines  - this should be the trimming line.
I can not do that With the 'plane cut' tool.
Is there another tool to trim the insole ?
hfcandrew
There is not a single 'tool' but you must perform a workflow of a couple tools.
  1. SELECT the surface you want to keep
  2. EDIT>SMOOTH BOUNDARY
  3. INVERT
  4. DISCARD
Watch this: https://autode.sk/2XrZpg6
skergeth
Hi Andrew,
GREAT !!!
It took me a little time to understand but now i got it.
Thank you so much 🙂
