Meshmixer
Welcome to Autodeskโ€™s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
How to set a screw thread into a cone perfect centered
2 REPLIES 2
skergeth
365 Views, 2 Replies
Hi MM users,
i would need your help for a special task:
I have to set a internal screw thread into the bottom of a printed cone (see picture).
There will be turned in a screw for a grinding machine.
The thread should be very good centered so that there will not be any imbalance when turning around with high speed.
Is there a workflow to do this or is it only possible to set it "by hand" ?
Thank you for your help ๐Ÿ™‚
2 REPLIES 2
hfcandrew
in reply to: skergeth
Need to use pivots: https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-EDB35D1E-13EB-4689-A83E-DD8C1D71CDC2
Generate facegoups, drop a pivot at group centre on both objects, align one object onto the other, then boolean difference.
skergeth
in reply to: hfcandrew
Great !
10000000 Thanks ๐Ÿ™‚
Technology Administrators
