Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How to save segmented dental model as stl with teeth still segmented?
4 REPLIES 4
adslimq2
349 Views, 4 Replies
I am trying to segment individual teeth on a dental model, then save as an stl, so that the teeth stay segmented when opened in another programme (Geomagic).
I am new to this, sorry!  I am gradually figuring out how to segment the teeth, and create a new face group from each tooth.  If I highlight them all in the Object Browser and Export, Geomagic reports that the stl is corrupt or an invalid format.
How do I save this as an stl?  Am I missing something?
4 REPLIES 4
hfcandrew
in reply to: adslimq2
Post your .mix
adslimq2
in reply to: hfcandrew
Here's one attempt with a couple of teeth segmented, thanks.
hfcandrew
Thanks. You will need to export each item separately.
If you want them as one file though. you can try highlighting all 3 items, then exporting as a 'STL ASCII' instead of 'STL Binary'.
adslimq2
Thank you!
Saving them all separately allows me to import them into Geomagic, and they seem to align.  I will need to check to be certain, but it looks like you are the genius I needed!
Exporting as ascii seems not to work, but this should.
