Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How to modify the donut primitive
3 REPLIES 3
alanFM6A9
1033 Views, 3 Replies
How can I change the inner diameter of the torus or donut primitive?
Thanks, Alan
Labels (1)
3 REPLIES 3
hfcandrew
in reply to: alanFM6A9
There are a dozen different ways depending on what else you want changed or to remain the same. Can't to be more specific.
Will most like involve A: Transform or B: Select>Edit>Soft Transform.
alanFM6A9
in reply to: hfcandrew
Hi:
Thanks!  That was the help I needed.  I want to make a thin donut, i.e.
big hole in the center.  I see I can do that with Select -> edit -> offset.
Thanks again, Alan
alanFM6A9
Thanks!
That was the clue I needed.  I want a thin donut, i.e. big hole in the middle.  I see now I can do that with select -> edit using soft transition and distance.
Thanks again, Alan
