Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
how to merge flange + tube in 1 object
10 REPLIES 10
Message 1 of 11
davidroland78
495 Views, 10 Replies
Hi. I need help how to merge or union or weld ( which commands are here used ) the flange to the tube ellipse dimension.Any suggestion step-by-step i will appreciate. I try it in 3D MAX to do it,with help from forum,Screenshot (34).pngbut with no success .Thank youScreenshot (26).png
10 REPLIES 10
Message 2 of 11
MagWeb
in reply to: davidroland78
Hmm, looking at the MM screenshot: There will be several issues to solve. There seems to be a hole in the flange, there are self intersecting issues at the flange, there's a wide gap between both objects.
Makes me wonder to see a different appearance (a closer gap) in 3D Max.
Could you post a zipped mesh as an attachment (or give me a download link via PM)? Otherwise it's hard to give you some decent advice of how to repair and join. Think this isn't a one click issue...
Gunter Weber
Triangle Artisan
Message 3 of 11
davidroland78
in reply to: MagWeb
I find it a way to zip this max file , but first i do it in 7 zip and after in zip.file . Awesome.
Message 4 of 11
MagWeb
Should have mentioned: I'm on macOS and no 3dsMax for Mac.
So maybe the mesh (.obj or .stl) output from Max or a .fbx?
Gunter Weber
Triangle Artisan
Message 5 of 11
davidroland78
in reply to: MagWeb
Here is the file in obj.
Message 6 of 11
MagWeb
The flange part owns some interior cavities:
mid-horizontal cut of flangemid-horizontal cut of flange
Guess you do not need those cavities and you want to close the gap between flange and tube.
(After importing the source as a single file do EDIT/SeparateShells to split flange and tube.
Now we need to get rid of the flange's interior, self intersecting surfaces:
The flange object being the active one go to EDIT/GenerateFaceGroups:
Ohne Titel 2.jpegThis creates a group for the upper (here blue) and lower horizontal surface of the flange.
Go to SELECT and double click both groups to select them:
Hit X to discard both:
Run EDIT/SeparateShells:
Click on the outer ring of the flange to find it in the object browser. Now activate all other parts of the flange (image above) and discard them(hitting X)
You should end up with a scene like:Ohne Titel 7.jpeg
Now go to ANALYSIS/Inspector and do AutoRepairAll:
Inspector fills both boundaries with a plane surface:
The flange is OK now.
Switch to the the tube. We need to remesh the low res tube for proper welding.
Do SelectAll by hitting Ctrl+A
And run Edit/Remesh at RemeshMode:LinearSubdivision at a high Density:
Ohne Titel 12.jpegAccepting this result activate both objects and run BooleanUnion:Ohne Titel 14.jpeg
Should give you this final joined mesh:
Gunter Weber
Triangle Artisan
Message 7 of 11
davidroland78
in reply to: MagWeb
I need those 4 holes in the flange. I leave it them there but i can't do with the Hollow to scale the holes to be round not ellipse and to be HOLLOW.
 The tube can be do it to be hollow too?
I can't find the UNION. I searched on net ,but nothing.
Screenshot (40).pngScreenshot (41).pngScreenshot (42).pngI can't take out the crack in red. Any idea?
Thank you.
Message 8 of 11
MagWeb
If you need the holes position but round shapes you'll need further steps.
After separating tube and flange, create face groups on the flange. Now make a duplicate of the flange.
On this duplicate (the tube and the original flange hidden) do a horizontal EDIT/PlaneCut
Go to SELECT and select the group created by PlaneCut by a double click.
Hit "I" to invert the selection and "X" to discard all but this .
The result should look like:
Now go to EDIT/CreatePivot. Set its PlacementMode to SnapToBoundaryCenter and double click near to the boundary of the holes. This drops a pivot marker to the center of each hole.
Now you may hide the copy of the flange or even delete it.
Show the original flange and do the repair process as described above.
Go to MESHMIX and switch to its Primitives library. Drag its cylinder onto the flange. Now dragging the white sphere in the widget's center near to a pivot it snaps to it. Set its Dimension value to the desired diameter of the hole. Hit "D" to drop it at the current position. Drag it to the next pivot, again hit "D" aso until you got a cylinder on each pivot marker (The objects created by hitting D might not be visible as long as you're inside MESHMIX or didn't navigate to a different view but should be shown in the object browser).
Now combine all dropped cylinders and run EDIT/Transform to scale the cylinder along Y to make sure that they intersect the upper as well as the lower surface of the flange.
Now activate the flange object first and (while you hold down Shift) the cylinders as the second object. If there are two objects active you'll find the Boolean operations in EDIT.
Do BooleanDifference to subtract the cylinders from the flange:
Accept this result.
Now show the tube and activate it as a second object.
Run BooleanUnion ...
Gunter Weber
Triangle Artisan
Message 9 of 11
davidroland78
in reply to: MagWeb
Is a way to resize the dimension of the middle ellipse hole? Or the other 4 litle holes?
 Can you help me please to do to this flange a neck like in this picture : lap-joint-flange.jpg in the inside ellipse part?
I need a flange to be father and mother one.
Thank you.
Message 10 of 11
MagWeb
Hmm the repair workflow above works fine here. Maybe you did some transform or scaling accidentally?
Did you align the source object (still as one object) to the ground plane properly ?
If you end up like this and you want to get the neck:
Make a duplicate of the tube and do EDIT/Planecut a bit higher than the neck will end:
The tube is of poor mesh density. So we want to increase it first:
SelectAll and run Edit/Remesh in LinearSubdivision mode at max Density (hit W to see the wireframe):
Again run Remesh. This time at RelativeDensity mode also at max Density:
Now run Edit/Offset and set the offset to the value your neck should get:
Leave SELECT and run EDIT/Planecut. Position the plane where the neck should end:
SELECT this new surface by double click, invert the selection hitting I and X to discard all but the ring:
SelectAll of that ring and run Edit/Extrude so the extrusion intersects the flange:
Make a duplicate of that tube and use EDIT/Transform to scale it down a litte bit. Its inner surface should clearly visible:
Activate the flange first and holding down Shift the smaller tube as a second object. Run Boolean Difference:
Accept , Select the inner disk and discard it:
Activate the bigger tube and the flange. Run BooleanUnion:
Again make a copy of the flange. Activate the tube object first and the copy of the flange as the second object. Run BooleanDifference:
If you don't want to keep it you might cut off the lower neck:
Now the tube fits perfectly to the flange and its neck (a cut through):
Hope this is what you want to get?
If not, please give some sketch of what it should look like.
Gunter Weber
Triangle Artisan
Message 11 of 11
MagWeb
in reply to: MagWeb
If you want to get a female flange as well. Simply make a copy of repaired flange without neck, Transform it over the male part. Make a copy of the male part as well. Maybe you need to extrude the neck a bit so it's over the female part and do a BooleanDifference:
male red, female yellow.male red, female yellow.
Gunter Weber
Triangle Artisan
