Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How to measure circular ?
1 REPLY 1
skergeth
1042 Views, 1 Reply
Hello to all,
i would need to measure a scanned foot around the ankle (circular)
Is this possible with meshmixer and how to do it ?
Thanks for helping.
1 REPLY 1
hfcandrew
in reply to: skergeth
The short answer is: "No there is no simple tool for that in MM."
The long answer is: "Yes. However MM only calculates and displays surface area in the 'Stability Tool.. So you must use an overly complicated MM workflow using some math and logic to get the surface area of a strip that is exactly 1mm thick because if Area=LxW  and your width is 1mm and your area is also known then that gives you your length."
Watch: https://autode.sk/2RF3F7F
