Announcements
how to fix meshmixer not opening windows 10
hey guys
after installing mesh mixer on windows 10 and it just not opening at all and trying to fix after reading the forums and not finding anything that would work. I gave up to be honest and went to another program instead and that did work either but... In finding the solution for that one I found that it worked for  mesh mixer also so here are the step hope it works for you.
step 1 . go ___hyperlink removed___ and download the file.
step 2. go to your download folder and unzip the file and open it once its unzipped.
step 3. copy the file named opengl32.dll
step 4. go to your desk top and go the the meshmixer icon an right click and go to open file location. then paste the file in the the file location.
step 5. after pasting the file into the file location close the window.
step 6. then try and open meshmixer may take afew seconds.
hope this helps you guys.
  • Help
Replies (16)
hfcandrew
Awesome, thanks, good to know. There is a post on this forum every month or so regarding someone not being able to open MM.
I pray to the Autodesk Gods for another MM update, but they've made it pretty clear a few times on here that won't be happening.
this doesnt work for me ๐Ÿ˜ž
hfcandrew
Try 3.3 instead of 3.5.
still nothing
Thank you for helping me out....
Thanks. It worked for me with v. 3.5 and Virtualbox 6.1.20 (Ubuntu 20.04 host/Win 10 guest).
steffen_anders_adsk
Autodesk Support
Autodesk Support
I'd love to pin this, but Autodesk cannot endorse substituting system files from unverified sources.
Steffen Anders
Autodesk Netfabb Team
Netfabb resources: Online Help โ€ข Netfabb knowledge base โ€ข Forums โ€ข Homepage โ€ข YouTube
lptrung
Observer
Observer
Thank you very much. I just fix it
wsorich
Community Visitor
Community Visitor
Thanks, Copying the Opengl32.dll file into the meshmixer folder worked for me. Working with Windows 10 and Meshmixer v3.5.474
Thanks a lot. The problem was solved easy and quickly. I had this problems four months ago and wont found the solution until arrive here.
CGBenner
If the fix is to place opengl32.dll into the program location, there is no need to download this file from the internet, which is in fact a very risky thing to do.  This file can be found on almost every Windows OS pc, in the System32 folder under the Windows folder.  If that is what works, simply COPY (don't MOVE) the file to the program folder.  Files downloaded from unverified sites may contain viruses, adware, spyware etc... that put your computer and your data at risk.
Chris Benner
Industry Community Manager โ€“ Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Well if program worked I wouldn't of had to do this. And I am only sharing what I found that helped me. I don't post in forums ever but I thought this could help other people which is has. I wouldn't post anything that would lead to causing harm to people's computers.
waldmeier.productionsY4JMD
Community Visitor
Community Visitor
how can this fix of yours work if meshmixer installer doesnt install anything when on windows10?
Community Visitor
Community Visitor
Strange... had same installing problem.
first nothing happened..
semingly the installer installed the software. but somehow in a silent way..
Absolutely no desctop shortcut has been created. and windows search does not find the app.
however when i manually browse installed softwares in (C:) i can find a meshmixer there and surprisingly it runs..
just no desctop setup..   Weird!
juan_ita41
Observer
Observer
hasta el dia de hoy diciembre de 2024 sigue el mismo problema apezar que tenemos todo actualizado...tiene que ver algo mas a fondo...pero es bueno que existan perzonas como ustedes que con su experiencia con los mismos problemas nos dan opciones para arreglarlo......MIL GRACIASยกยกยกยกยก
juan_ita41
Observer
Observer
QUE RAROยกยกยก TRADUJO MI RESPUESTA DE MANERA DIFERENTE COMO LA PLANTEE
