Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How to fill in a solid
4 REPLIES 4
hollie8YDY9
439 Views, 4 Replies
I have some 3d scans of people and I'd like to give it a back and bottom, 90 degrees to each other.
How to I fill this in like a solid?
(think "book end").
Thanks heaps experts
Tags (1)
4 REPLIES 4
MagWeb
in reply to: hollie8YDY9
Nice scan! Photogrammetry?
Several strategies possible...
Here's the one I would do:
Hit Ctrl+A (Cmd+A on Mac) to select all.
Run SELECt/Edit/Extrude, set its Offset to a negative number big enough, Direction to Constant and EndType to Flat.
Accept.
On the result run EDIT/PlaneCut twice:
Gunter Weber
Triangle Artisan
hollie8YDY9
in reply to: MagWeb
Hi Magweb, thanks for taking the time to do those solutions I'll try them out this evening and let you know.
I have an Artec Eva scanner and it does amazing scans. This is a good one too.
I am actually building a photogrammetry rig too. Almost finished!
Photogrammetry rigPhotogrammetry rigArtec EvaArtec Eva
hollie8YDY9
in reply to: MagWeb
Sorry,  that didn't work:
It just made the whole thing flat, unless I did something wrong?
MagWeb
hmm, your settings are ok - except the negative Offset value needs to be smaller (maybe -120 ?). The flat surface must not intersect the old surface. But this should not be the reason of this unexpected preview result... The flat surface is the Flat projection. That's ok but it should be connected to the old surface all around.
Maybe that's just a rendering issue of the tool's preview (not that likely). What happens if you Accept?
More likely there's some error on you mesh you need to fix at first. What does ANALYSIS/Inspector detect? There should be only one blue marker pointing to the open boundary. More blue (open boundaries), any red(non manifolds) or magenta (isolated pieces) markers? If so, click on those spheres one by one to repair that issue . Do not run AutoRepair as this will close the outer boundary too.
Gunter Weber
Triangle Artisan
